1 - 20 of 40 Posts
1983 240D, 1981 300TD Wagon, 1984 Euro 300D (SOLD)
So, I did this Block Heater Install last spring while I was doing a bunch of other crap on my 1983 240D. Maybe there are some other similar threads that have the same info on here that I didn't see, but nonetheless, some of those threads weren't complete enough to help me with everything. I took a ton of photos and documented all the steps and part numbers, so hopefully this will help all ya'll in the future with a similar install, especially cause winter time is coming up. So here ya go, first things first, here is the block heater I used....
Discussion Starter · #2 ·
I sourced the block heater from the closest Mercedes Benz Dealer to me (Westminster, if you are in Colorado, use them; they were awesome and not any more expensive than any other place). I chose to use them after 2 failed attempts to get the correct part through Car Quest (worldpac) and another attempt through a European repair garage here in Fort Collins. All of the block heaters that they found for me had too small of a bung and incorrect threads.
W-1-2-3 Go!
Did you have difficulty with the installation? How did that go? With a 240D like yours access will definitely be easier than a 300D turbo or non-turbo. The metal around the block heater is typically thinner from what I've seen, so it's a bit risky opening the plug to install the heater.
My 300D came with a block heater, never needed it though.
With the use of other block heater threads on this forum, I was able to get all the correct tools that I needed for the job. I used a 3/4 S&K Breaker Bar that I bought off Ebay for a song, a 3 or 4 foot pipe for added leverage and an Armstrong 19mm Hex Impact Socket (most expensive tool I bought for the job, $55 bucks through Sears).
W-1-2-3 Go!
Wow, I didn't realize it was that big of a job. Nicely done, and thanks for documenting the process!
Good call doing it early on before the cold weather sets in.
Discussion Starter · #6 ·
I seriously did not have any difficulty with the install. Once I got the intake outta the way (I replaced the exhaust and intake gasket too while I was in there) it was a breeze. I was loaded for bear, ready to bust my knuckles and was prepared for the worst, but I just put that socket in and gave it 2 or 3 quick cracks upward and it cracked loose. I used my legs and the leverage of the bar to do so.
I did notice that it required the removal of the starter to get the socket in there because otherwise there wasn't enough room but that was not a problem besides a funky placed bolt that needed removing (see picture). I took a picture so that everyone can see the bolts that hold the starter in, the bottom one was a little hard to find at first and get the leverage to crack loose. That was the hardest part to the job, cause there didn't seem to be a lot of room down by the bell housing to get at it.
Discussion Starter · #7 ·
Thanks! I really did have a lot of fun doing the job. It taught me more about my car and I enjoyed being able to document it and show everybody else what they may need.
Discussion Starter · #9 ·
For anybody that is doing a search for block heater part numbers and whatnot, even though you can see the part numbers in the pictures, the part number is: A606 200 00 96. So you can just cut and paste that. I recommend a Benz dealership, although my friend GreaseDiesel.org bought his from Autohaus and I think it is the same. Seems to be genuine Mercedes but manufactured in Canada. Go figure. That part number may work for 300D and 300TD's too, but I'm not sure. I would imagine so. Like MBeige said, I'm sure it'll be a bit more involved if you have a 300D with a turbo.
Here are a couple last pictures of the plug I removed and the block heater installed.
Discussion Starter · #13 · (Edited)
I believe it is a 300W Heater. It didn't come with any other info. Just the box. I haven't had to use it yet because I just did it last spring. But there will be opportunity to use it shortly. I'm just glad that I have it so that I can use it when I need it. It was a good upgrade, I think.
Discussion Starter · #15 ·
That's what I saw too, but I thought it looked like a 3. Ha! 500W is better I guess. I havn't had to use it yet to find out.
Discussion Starter · #20 ·
Well, like my friend greasediesel said, I'll have it on a timer. A couple hours before it's time to start it up and drive. I don't think there will be any need to leave it on for longer.
1 - 20 of 40 Posts
