1982 380sl
the cigarette lighter on my 82 380sl is dead, no power to the socket, where should i look to fix this? thanks, Kevin
1976 450 SLC. (working, in need of paint)/1987 300E/1989 635 CSI/2004 Honda Element (appliance)
Fuse
Have you tried looking at the fuse? Fusebox is generally located at the footwell of the passenger side compartment. Smallish plastic cover that pops off, and has a list of all fuses.
1986 560 SL
Just a thought ...
How have you determined there is no power at the socket? With a meter or by plugging something in it? The MB socket is a different size than regular, and some devices won't work in it.
1997 SL500- 40th Anniversary
...Also, if you are not aware, the socket is powered only when the key is on, or the engine running...
Always Remembered RIP
1979 280sl 4 sp w/ac 1957 MGA 1998 volvo xc/70 2004 F150
Pull the whole astray door off, there is a brass slide contact on the left side that weakens with age, clean it and pry it out a bit to make a better connection.
1982 380sl
thanks to all
Wow, thanks for all the suggestions. I checked the fuse box, no issues. Then I pulled out the ashtray and frame unit and sure enough, there was enough build up of crud on the copper slider to prevent contact. I cleaned it up with some 600grit sandpaper and it looks like new again. Also cleaned the ashtray contact. Voila, connectivity has returned. THANKS to all.
:thumbsup:Thanks for letting us know of the outcome of the suggestions... I learned a little myself...
