Hello. C280 2007.... Left a light on and got a dead battery and had to jump it off with a booster box. Works fine but now have a srs malfunction visit the workshop message. Have restarted the car several times but no luck. Does his message expire or retest itself? Require a computet to reset? Any ideas? Thanks
No, transient SRS errors won't reset like ECU codes. This probably was due to low voltage or a surge when jump starting. You're going to have to get someone with SDS to check and reset the error for you.
