2003 W211 270CDI + 2000 w163 ML320
Hi to all,
I've bought a ML320 from 2000 in September. 3 of the dashboard lights don't turn on at startup
Security belt, Engine check and airbag off :
2611644
I've checked the bulbs and they are OK, in addition, I don't have any error codes with an autel MD802 all systems.
So I wonder if that's normal ?
Many thanks in advance !
2003 C320 coupe, 2000 ML320
On my 2000 ML320, position #1.. AIR BAG OFF is "ON".. position #2 it's "OFF"... SEAT BELT is "ON" in #2.. CHECK ENGINE is "ON" in #2.. You might want to take off your gas cap to see if it will throw a code and turn on the CHECK ENGINE light...
Thanks, good point for check engine... And I'll recheck this WE in position 1 for the airbag...
For the belts, if you run without fasten your seat belt does it sounds ? Mine doesn't
"For the belts, if you run without fasten your seat belt does it sounds ? Mine doesn't "
YES.. it beeps.. But it might go out after a while.. not sure, I've always got my belt on
Ok thanks, I suspect one of the previous owners didn't like to fasten his belt :) is there any fuse for each lights ?
