Hi! I have an 07 E320. I have a strange problem with the dash lights. Not sure if I turned them off somehow or if there is a problem. Certain gauge lights aren't working. The speedo needle, tach needle and clock arms light up. The temp and gas bars light up. What doesn't come on is the lights to see the numbers on clock, speedo and tach. Center display works fine. I can see the speed using that at night. Is there a problem or is there some setting to turn these back on? Thanks!
