The light behind the outside temp guage is not working. The temp looks like it's working though.
The dash has two screws in the perspex, so I am assuming you just remove these and replace a bulb?
If so what size bulb does it take, as I want to do the job in one go.
TIA
Vito 111CDi 2004
Pop off the plastic covers then unscrew the screws. You need to take the offside vent out so you can reach in to push the dashboard out.
Standard automotive dashboard bulbs fit perfectly.
there's a massive thread on here about dash bulbs for some reason if you have alook for it.
ta
Adam.
ta
Adam.
Thanks Adam,
I did see that thread, but the dash looked different from the one in the 280.
As long as I know they are standard dash bulbs, I can pick one up from Halfords.
