I have pulled my cluster out several time to replace bulbs and then to install white face gauges. The cluster pulls streight out. First, run your steering wheel all of the way out and down to get it out of the way. Then put the tips of your fingers in the lower outer corners of the cluster. You have to flip your hands over so that you thumbs are facing down. Pull your hands away from one another so that you have enough grip and pull the cluster twords you. If your cluster has never been removed before this my require a couple of trys but the cluster does pull out. Once out there are two connectors that need to be unplugged from the back of the cluster but that is it.
