1 - 1 of 1 Posts
The turn signal audible on my 1996 S 320 stopped working. I replaced the Multiple Function Module located behind the fuse box located at the fire wall on the drivers side. The turn signal audible now works but the Exterior Lamp Indicator stays lit. All of the exterior lamps work. I have cleaned the bulb bases as well as the grounds. Any ideas on what could be causing the Exterior Lamp Indicator to stay lit? Thanks. Tom Greasel
1 - 1 of 1 Posts
