2001 C320
Living in Southern California, we have more than our share of rain. Last month i noticed that the fog lamps on me 2001 C320 had condensation. The dealer said to turn on the fog lamps to dry them out.
I have done this, but the lamps never truly dried out.
Any suggestions?
2004 W203 C180K Elegance Sport Sedan & 2005 W209 CLK280 Elegance Coupe
there must be a small hole in the lamps to let the moisture in.. i have noticed some japanese cars also suffer from this in their headlamps.
you either need to fully re-seal the damaged lamp, or replace it. should be under warranty anyway
2001 C320
The dealership took care of this. The lamps never dried out, so the dealer replaced them and under warrenty of course.
00 C-230, 04 C-240
You must have driven thru standing water. The fog-lights are mounted low on your car, & this is what happens. I used to remove my lights (not that difficult on most cars, since the lamp assembly is only connected with two screws to the housing) & use a hair drier to dry them out.
