SO over the weekend i damaged glass that is covering LED turn signal on passenger side mirror, is it possible to just replace that or do i need to buy entire new mirror ?
Can someone point me in the right direction ?
P.S. 2009 ml350
2005 ML350 SE Black
just replace the LED
if you move the mirror all the way in and down you will see a small clip that holds the outter cover on just push that in with a small flat blade screw drive and slide the cover off. The lens lamp is held on with 2 small torque screws.
My new lens lamp cost about 77usd good luck easy fix
