Hi everyone -
I'm also reporting success! ...
If you are able to, post some photos, of your work, for members to see.
Hi everyone -
Removing the TeleAid without reprogramming will definitely cause issues. I tried disconnecting it and I got a permanent loss of traction (triangle) warning.View attachment 2781418 View attachment 2781419 View attachment 2781420 View attachment 2781421 View attachment 2781422
Follow up on the audio issue, thus far I think it's the fiber, but not certain. The plan is to do fiber straight from the HU to the amp just like the previous poster, and I'd like to use the existing cable, so I see interior teardown in my future to remove the changer, teleaid and pull the fiber out. Perhaps not the right place to ask, will removing the teleaid entirely without updating the system via SDS create any issues, or should I leave well enough alone? As with many, I don't have access to SDS (need to buy one, recommendations?), but I also know when to be grateful for what is and let sleeping dogs lie....
Thanks everyone.
Were you able to resolve this issue? I have a similar problem the amp continually clicking only I have no audio.I’ve got a 2002 ML500 with the blue box. Got it working the other day but it takes about 5-10 minutes (sometime sooner sometimes longer) for the audio to turn on. The amp just clicks away before that. The audio stays on until the car is turned off.
The decoder is connected directly to the power amp with direct D2B cable.
Any idea what this could be?
Seems like the decoder can’t seem to wake the amp up for awhile. It tries and tries then eventually it comes on. I’ve tried tapping the ACC from different sources with the same result. Using the pink wire from connector C to wake up.
Welcome to BWWere you able to resolve this issue? I have a similar problem the amp continually clicking only I have no audio.
I haven't messed with it. Give me good ol' RCA cables any day of the week, thanks.You'd have to get feedback from members @wallyo and @Sam Cogley, on the DB2 details, or others that have recently played with it.
Welcome to the forum ixlattice,How do you bypass the teleaid? i cant find the orange cables anywhere near the console underneath the passenger seats front.
I have not and have no desire to mess around with the fiber optic converter boxes. I have one bypass loop to plug in for the removed TeleAid module, the rest of the audio system is just getting entirely replaced.You'd have to get feedback from members @wallyo and @Sam Cogley, on the DB2 details, or others that have recently played with it.
Just got mine working!!!!! Thanks you so much for this tip about FO cable length. The cable I have was about 15 feet. I just had it coiled up under the dash. It is a direct connection between the decoder and the power amp. I shortened it to about 3 feet and the sound now comes on right away! I had it working before but it sometimes comes on right away but usually after 10-20 min. Sometimes longer. This had been driving me crazy for the last 6 months.Update... After studying some of the D2B specifics... there are max wire lengths for D2B wires with and with one or two couplers involved. If I'm understanding this correctly, the loop from amp to CD changer (with coupler) to TeleAid (with coupler) and back to the head unit is just too long. This might work on the European models that just have a CD changer but no TeleAid. Like others in this thread, I'm now running a direct wire between the D2B adapter and the amp and it appears to be working. I've only messed with it for a little bit but I also seem to have the issue where sound only starts working after a couple of minutes.
