Hello!
So after having some weird sounds with my CV axle, I replaced it with another (used) one. Sounds are gone.
Having my old CV axle out, I wanted to disassemble it and take a look at it, what's inside.
This is not a tutorial. I will explain the way I removed CV axle from car and how I disassembled It
So, to remove the axle:
I could not find the procedure of CV axle disassembly anywhere so I thinked through It and I did it!
So, to dissasemble this massive structure, I:
The balls and cage on the whell bearing side
The differential side
After seeing these images, how do you think - are these components reusable? Like there is no major wear. The shiny parts on components are made from balls riding on them. there are smooth and no metal is missing. I think a lot and good quality new grease will get these ones running for many more years... or am I wrong?
- I removed the wheel center cap
- "Unbended" the axle nut "security tab"
- Using 32 millimeter head and a lot of force I broke loose the axle securing nut
- Jacked up the car, put it on bricks (my version of jackstand
), removed the wheel
- Using 12 star head (10mm) removed the 6 bolts, holding the CV axle to the differential (before doing this, cleaned the bolt heads so that nothing strips)
- Removed the exaust (final muffler) from it's end rubbers; let it hang
- Removed the sway bar link carefully, taking the load off the sway bar
- Removed the plastic cover from lower control arm
- Removed the large bolt, that holds together knuckle with lower control arm (In my case it was 21mm nut and bolt head was 22mm)
- With 60 hits using large hammer and a lot of WD-40 smashed out the CV axle from hub splines (have heard that this can ruin your bearing; mine is still fine...)
- With some thinking and maneuvering removed the CV axle completely.
- Using a flat blade screwdriver and hammer (hitthing the lip of cover) removed the cover
- Removed the snap ring which allowed the balls and its ring to slide off
- Removed the "casing" where balls ride
- Removed the other cover, using the same technique as in 1st step
- Removed the casing from the balls
- Removed the balls with cage and now I had bare shaft.
