1983 240d - 1985 300d - 1984 280sel
Hi- I just found out that the lugs that I have are too long for my new wheels. Is it safe to cut off about 1/4 in. How easy is it to do without messing up the threads?
'81 300TD Turbo
Well, if you can cut them straight and want to do it 'right', you can cut them and then get the correct die and run down the lug to clean up the threads. Personally, I'd rather buy the correct lugs than mess around cutting all of them.
Benzless for now...
Cutting the lugs will not mess up the threads, but it will definetly take more time than it's worth and probably look like crap against your new rims.
Nevermind- just bought a new set of chrome ones off ebay for $28. Thanks anyway[:D]
84 300TD, 2004 E320 wagon, 2006 CLS55,
For others information, when ever you cut a bolt, use two nuts right next to each other and cut near the face of one so that both nuts will have to come off the cut side of the bolt. This greatly eases the bolt or next nut threading, and reduces the chances you'll need a tap and die set.[8D]
