1 - 20 of 41 Posts
91 500SL 37k,90 300SE sold, 91 300E sold , 92 300E137k ,02 Kia Sedona ,I know..... its a Mini van.
Working on Dieters fuel leak at pumps, was leaking from the top pump,so dropped the entire assembly tightened everything up,reinstalled,still leaking ,also from fuel filter outlet,its weird how I replaced everything new last Jan,and now decides to leak?
Anyways I need the sizes for all the crush washers,the one at fuel filter is thicker than the others,and yes I did use new ones last time,I just don't get it?why!!!!:mad:
Are you using metric or the "only the devil could love" US inch sized washers???
Suggest you use new washers from the dealer , AutohausAZ, germanstar.net, etc.
Sometimes the pump body itself develops hairline cracks which causes a leak that spreads. Seen it especially on cheapo aftermarket pumps.
As far as I remember the fuel lines don't have crush washers? Only delivery valves?
I never replaced those while working on the engine and they don't leak.
I always make sure the washers don't have scratches, or sand them off, use lot of air for cleaning and most of the time double tight them.
All the crush washers were from Autohauz,Az,I just need new ones again all the way around,1 1/2 hr job under there what a pisser! funny did my other 2cars no problem,this one is haunted!
1990 Mercedes Benz 300E
I had a fuel leak at the said crush washer after replacing my fuel pumps this spring. It turned out to be a defect in the washer and replacing it solved the problem. New washer BTW.
Well here's their page on washers,the one for the fuel filter is diff from the rest
Your Parts Search Returned 4 Part(s)
The copper crush washers have rings on both sides,once tightened that's what makes the seal,really cant reuse them,tried sanding them lightly to no avail ,wonder if Napa has them?
where did you get them?don't say dealer! none close by!
Discussion Starter #11
So I'll try Napa tomorrow,need 3 12mm Copper Seal Washer; 12x16x1.5mm , at each check valve ,banjo location ,for a total of 6 and 2 thicker ones at filter location
Discussion Starter #13
What do you mean??? MB of Escondido is less than 30 minutes away from you.
I hate driving down that way! If I have to I will or better yet have a friend down there who works in the parts dept ship them to me,rather go the Napa route if they have the size,5 min away,any one by chance know the part#?
1999 E320, 2000 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
I bought my fuel pumps along with the crush washers from Autohaus AZ. I never did used their washers........their washers are smaller (12mm i.d. x 16mm o.d. x 1.5 mm thickness) vs dealer's (12mm i.d. x 18mm o.d. x 2 mm thickness.
The dealer/stealer also charged me $2.50 ea (list $4.25 :eek:) vs AZ .24
On my fuel pumps (oem Bosch), the washer between the pump and the check valve (10 mm i.d. x 15mm o.d. x 2mm thick) is smaller than the ones at the banjo location.
BTW: fuel filter use the same size washers as the fuel pump at the banjo. Part #007603-012110
Go to the dealer and than go Mi Pueblo in east part of the city to pick up hot bunnies and very cheap and tasty fruits and vegetables. I was buying juice-grade oranges for 6 cents a pound.
I don't hesitate to drive 550 miles on any business excuse because just the price difference on groceries covers the fuel cost. Bay Area is pretty expensive to live in.
After shopping you can stop across the street at Town buffet with excellent steaks and seafood. I think weekday price is around $10 for dinner.
Discussion Starter #18
Your right the ones from Autohauz are on the thin side! and just don't do the job.
Why not just order from your friend at MB Escondido and have it shipped since you don't want to drive 30 minutes???
Yes, you'll pay a bit more but at least you'll be getting the exact crush washers you need.
1 - 20 of 41 Posts
