okay another cruise control issue and i have been at this for about three months... so i know i got 2 good working cc amps. but...they only work properly when i spray cleaner on the amp connections and circuit board, but the next day when i drive to work no cc....any suggestions.
The socket connectors are weak and don't hold as tight as I like. Try removing the housing and pinching the metal connector closed a bit. Careful not to go too much as they break easily.
Where IS the cruse control amp? I have an 81' 300D Mine only works up to like.. 55 MPH anything after that and it won't hold. I would like to re solder the connections
FWIW, I had mine repaired by GDL-Online 6 years and 150,000 miles ago. It has worked perfectly ever since and I use it all the time.
