Mercedes 300 SD, 1985
Hi,
My cruise control does not hold. It will speed up when holding the lever, but does not hold the desired speed. Specific reason for doing this? Amplifier?, actuator?:confused:
thanks
1993 300TE, 1995 E320 Wagon
It's almost always the amplifier, found under the dash above the brake pedal. Finding a working one is sometimes problematic (they are relatively common at scrapyards, but I can't test one out, as I have the wrong type of car, and they are often model- and year-specific, I've found).
There are several threads on trying to resolder "cold joints" inside the amplifier, but these repairs are not always successful. I've also seen a repair of the 12-pin connector, but again, this may not be the issue.
So you can see that you're going to have to try several approaches. Best bet for a DIY would be to get a couple from a junkyard (they range in cost from about $10 to $25, depending on the yard), and my experience is that about one in five or so work. But you'd at least have a couple to compare yours to. You can also buy a rebuilt unit from a guy in Morro Bay, CA-- I forget the company name though-- it is in one or two threads here though. I think he charges about $200, maybe $250.
1990 560SEL
Resoldering
I had the exact same problem on my '90 560 SEL. The cruise would take, then surge a few times before disengaging. After a while it stopped working altogether. You can get remanufactured cruise control ampliphiers from a few sources, and for a few hundred dollars, but I found that resoldering the circuit board in the ampliphier did the trick and cost nothing. There have posts before about the procedure.
