1995 E320 Cabriolet
Hey guys I did a search but didn't find any threads with my issue. I have a creaking noise coming from my right rear on the 95 cabrio. Took it to my mechanics and we got it up on the hoist but couldn't reproduce it on the hoist.
When I am going up a curb at an angle or when turning slowly I can hear it, seems like its coming from inside the car. Any suggestions are appreciated.
W124 Moderator
Dried out sway bar bushing link would be my idea. Easy and inexpensive part to replace.
Jayare
1995 E320 Cabriolet
Sonovagun, the noise can now be heard going over some cracks in the road and dips in the road. Will change those stabilizer bushings since they are cheap.
1988 "Zender" 300CE Coupe, 2009 Renault Koleos, 2007 Kia Rio Sport
I bow to Jayare's wisdom and advice.
Mine would have been more like :
Jack it up at the back, grab 2 cans of Selleys Lubricant/RP-7 spray and go wild !
Spray everything in sight like a tomcat on a night out !!!!
Suspension bushings,springs you name it - it got sprayed !
No more creaks and groans !
It's probably either sway bar bushes, or the big bush of the lower controll arm. Spraying stuff on it to make it stop making noises is no fix. If it creaks - it's time to replace. :)
And just to make sure; did you check for play in the wheel bearing? :)
1989 300E 125,000 miles, 2005 Acura TL, 2011 Hyundai Elantra Limited
Creaking
My noise came from the left rear sway bar bushing where it attached to a control rod. I took the joint apart and sprayed everything and the noise stopped about 9 months ago. Will need to reapply at some point in the future.
