2002 CL55 AMG, 1993 190E 2.3L, 2004 SLK320 Sport
As I slow down from about 40km to stop, my speedo is jumpy. It goes up and down until it stops at 0!
Basically, it seems to be vibrating up and down! I think I also hear a squeking sound from behind the cluster! You think maybe time for a new speedo cable?
thanks, SPIROS
1990 W124 300TE-24 3.4 AMG, 1991 W126 300SEL
hyprr1 - 4/8/2005 9:47 PM
thanks, SPIROS
I had the same problem too but didn't have the time to change the speedometer cable so I pull the cluster unit out and disconnect the speedo cable. Smeared some grease at the end of the cable and connected it back again. The ticking noise now gone and it didn't vibrate as much as before.
E220 1994
Me too. The problem started at one instance that I push the rod when the car is moving. Someone said that this may damage the speedometer gears and resulted in a jumpy needle.
