cracked upper pan
566 Views 5 Replies 5 Participants Last post by  Willber14
I hit a curb and cracked my upper pan. Does any one know if this part is available and were?:crybaby2:
1987 420SEL
Cracked the upper oil pan?
The dealer price for that part is in the clouds, so your best bet would be to replace it with one sourced from a wrecker.
Another alternative would be to have someone weld the cast aluminum. This can be done, and the pan doesn't necessarily have to come off, depending on where the crack is.
The oil would have to be drained though, obviously.
1993 300TE, 1995 E320 Wagon
+1 on getting the pan from a wrecking yard. I just happen to be planning an excursion to the JY later this week, so I can likely get one for you....
What model car/engine, and where are you located? Let me know...
Dave
1987 420SEL
One more idea:
If the crack is small enough, or something like the upper oil pan ever gets a small hole punched in it, you can try drilling the spot out with a suitable drill and then tapping for an NPT pipe thread (keeping in mind that a 3/8" NPT is about 0.635" actual major diameter, check the internet or PM back for other specific outside diameters) and then plug the hole with a standard pipe plug.
This would only work of course where the metal thickness allows suitable thread depths, but it's an option if you're ever faced with a crack/hole that requires cheap fixing.
