1 - 20 of 20 Posts
1986 190E 2.3-16, 1992 190E 2.3, 2015 GL350 BTC, and 2020 GLS450
Picked this up at Helms Brothers yesterday. It's for my daughter to go through law school. It has the all wheel drive, premium package, blind spot assist, the multimedia package, the comfort suspension and 17" wheels and all season tires.
It rides very nice.
Discussion Starter #2
7,000 Mile iol Change
The CLA got an oil change at 7,000 miles on October 7, 2017.
The oil filter is a 27mm hex cap that twists off to reveal a paper element and three rubber gaskets. Removal and replacement is a snap. Tightening the cap to wrist tightness is enough to seal it.
I used a vacuum unit to suck out hot oil. Formula M goes in and the job is done.
7,000 Mile Air Filter Change
The CLA got a new air filter at 7,000 miles on Octboer 7, 2017.
A T25 torx wrench easily loosened the four screws which do not pop out of their settings. They stay in but loose. Remove and replace the filter and retighten hand tight.
Cabin Filter at 11,746 Miles
The CLA250 got a new cabin air filter today.
The cabin filter is located behind the glove box. Access to it is through the starboard passenger footwell. A cover is tanged on and the filter is pulled down and out. A new one is reinserted and cover replaced. Job done.
The car is a treasure. I see I'll need some extra wheels and tires as a backup. The car does not come with a spare tire and instead has run-flats.
Oil Change at 14,162 Miles
Today the car got an oil change and filter at 14,162 miles.
New Tires at 21,762 miles, July 12, 2018
The CPO experience is not without its surprises.
The CLA required tires suddenly. The left front tire was damaged to the point that its sidewall material was peeling off and flaking. There was a plug in the tire that leaked. On the passenger side front, the wheel was bent and then straightened out. The repairman left a sticker reporting this.
So given four year old tires, in went a new set of Bridgestones. These are the run flat version in a 225/45 R17 91W. The speed rating matches that of the car, 168 mph.
The difference in performance was astonishing. Here is a vehicle with the fuel economy of a Hyundai (12 gallon fuel tank and more than 500 miles range) and acceleration to huge speeds in just seconds. Its a speed demon with nothing but economy and performance the two operating parameters. The 4matic also comes in handy to prevent swerving and squealing the tires on acceleration.
Whatever car has the gas in it
Congrats on the new car. Should last until she is done with Law School. Then she can trade up. Sounds like the perfect car for this car. Good MPG, Easy to upkeep, Not much that can go wrong, AWD and CPO Warranty.
Reactions: lomtevas
Inspection and Taillight Bulbs at 24,524 Miles
Today, the CLA got all new rear bulbs. The warning system alerted that the back up lights were bad and that the brake lights were bad. I replaced all except the orange bulbs which I could not easily find in a parts store.
There are felt caps at the rear of the trunk inner liner that easily pull off and reveal the rear of the lighting assembly. Pinch the tangs and yank on the plug and the assembly pops right out. Undo the plug and remove the lighting assembly and replace bulbs. Reinstall in reverse order.
It also got an annual New York State inspection and passed.
On the agenda is to replace the Group 48 AGM battery and auxiliary battery as these are almost five years old and weary. It needs new windshield wipers, a new serpentine belt and a greasing of the front engine pulleys. I'll get to these as the autumn progresses.
It's an amazing automobile given its power and economy! And I find the suspension to be totally excellent despite reports to the contrary.
Discussion Starter #11
Popped the Right Front Tire at 28,418 Miles and Replaced
The CLA fought with a road rut at 28,418 miles and lost. A new tire filled with nitrogen made its way onto the wheel. Rotated tires means the new tire is now on the right rear of the car. Job done.
Discussion Starter #12
More Tire Explosions, This Time at 29,576 Miles.
Here are more failed tires. The left front exploded and the right front bulged. Bother fronts were replaced on April 1, 2019.
Discussion Starter #13
Another Two Weeks, Now New Wheels at 30,000 Miles
The CLA needed new wheels after one rim cracked and another bent out.
Discussion Starter #14
Oil, Air and Wipers Changed at 30,101 Miles
The CLA got new oil and air filters and motor oil. The wipers were replaced.
Discussion Starter #15
The CLA passed its New York State inspection at 32,786 miles on September 3, 2019.
2603358
2603359
Discussion Starter #16 (Edited)
I sold back the CLA today to Rockville Mercedes. I owed $21,000 on the car, but it depreciated to $13,000. So I refinanced that amount with the purchase of a new car.
I will miss this car. It was a 200hp beast with remarkable handling. One day maybe this type of car will return.
Discussion Starter #17
RECOVERED THE CAR
2618208
My daughter found the car for sale on Craiglist from a dealer called "Peak," and brought the CLA back home. She was so upset I had traded it in that she took action to recover it. She did.
Discussion Starter #18
The dealer only put on 118 miles between trade (34,579) in and re-purchase (34,697).
2618338
Discussion Starter #19
Today the CLA got a pair of little Sylvania brake light bulbs.
I pulled the brake light facia off the trunk at the rear. I unplugged the driver side (blue connector) wire harness and pinched retainers. Out popped the bulb holder and I exchanged the blown bulb. I did the same for the passenger side.
Job done.
Discussion Starter #20
New Front Tires at 40,820 Miles
The CLA's front tires wore down to nothing since April 2019 but the rear tires looked new. So we bought two fresh tires (Bridgestone Driveguard 225/45 RF17 91W). They are mounted at the rear of the car and the older tires are now on the front.
2640097
2640098
2640099
1 - 20 of 20 Posts
