2012 ML350, 1999 ML320
Does anyone have a soft copy of the courtsey lamp schematic they can post or push my way? (1989 190e 2.6)
I tried viewing the one in FAQ's however the area where I need detail is quite dark. My issue I am having is the lamps all work, but when the doors open lights do not come on. I suspect it's the timing circuit or something leading up to that circuit. I also do not have seat belt lights coming on.
Thanks,
Bryant
85 190e/8v & 89 420 SEL
I just rewired mine and upgraded an 85 dome light to the newer/nicer 93 dome light.
Im a wiring guru. I do it for a living. So if I can help you in any way with questions email me. [email protected]
Here's the diagram, not sure if its any help.
This one below is for an 86/87. I think it's the same though. (newer style)
That did help and I eventually got a replacement unit from the local junk yard. Seems the timing circuit was not working. Everything works great now that I swapped out the overhead lighting unit.
Thanks!
