Told that I need replace both my engine mounts, which have "collapsed." How much should this reasonably cost. Also, if I'm not noticing any major driving problems, do I have to replace them? What's the danger if I don't?
Do the Mounts Yourself and Save a Bundle of Money.Told that I need replace both my engine mounts, which have "collapsed." How much should this reasonably cost. Also, if I'm not noticing any major driving problems, do I have to replace them? What's the danger if I don't?
If your going to have your engine mounts done you might as well get the trans mount done too. Replace the entire system if you will, so everything will be fresh. A broken motor mount will result in a minimal 20% loss of horse power. Your gas mileage will also be effected.Told that I need replace both my engine mounts, which have "collapsed." How much should this reasonably cost. Also, if I'm not noticing any major driving problems, do I have to replace them? What's the danger if I don't?
Indeed!Usually the big reason for changing the engine or tranny mounts is that it will cut down on the vibration at idle which usually becomes very noticable when the mounts collapse with age.
Just in case you still need a "how to", you may be interested in this: Howto: Change engine mounts - MBClub ForumsI did a search for DIY mount replacement (Engine and Tranny) to no avail. Anyone know where to find instructions on how to? I have a 1994 C280. Thanks. Michael
minimum 20% loss of horsepower? how come?A broken motor mount will result in a minimal 20% loss of horse power. Your gas mileage will also be effected.
