1 - 12 of 12 Posts
Mercedes 190D (2000cc) 1986
What's the correct oil pressure at regular temperature (hot) for a diesel engine on iddle? I believe mine is very low, under 1. On last service was detected a leak on the circuit and the oil pump was also replaced.
I believe it's different... but don't know if that's normal (always on 3). I compared others to mine, and they keep at 1,5 (+/-) on iddle and with just a bit gas pedal it rises right up to 3. Mine isn't like that, it only reaches 3 at middle ratio... for instance, if I go on 4 gear below 70 Kmph, even with pedal on bottom, it doesn't get on 3. (my 190D as only 4 gears)
'98 E300, '10 GL350 Bluetec
At operating temp, mine is at about 1,5 at idle and up to 3 at rpm higher than idle. It is a 2.5Turbo
mercedes-benz 190E 1.8 '91 102.910engine,mazda 1.6crtd dec'05
2,5 to 3
W201, W202, W203, W204, W205 Moderator
Amethyst 2001 C320 with 351,000 miles
Awhile back I think MTI posted the specs in terms of how many bar the oil pressure should read at idle and at full throttle. I searched but couldn't find his post. Anyone remember?
1993 Mercedes Benz 190E 2.3
I always thought the higher the better, but maybe I'm wrong. My car after a long hard fast drive will get down to 2.75 at the lowest. If you can't get any details on here you may check the rev.
190E 2.0 euro spec
mine is around one when cold and when it is warm it will be around 1.5
sometimes it is 0 when ideling(is this a word) should I worry about this??
It will go for a service within 200 km
Rik
1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
If i can remember correctly. The 16vlv is the only engine that should stay pegged at 3 while idling.
1 - 12 of 12 Posts
