It all started with a drip drip drip... Car was running fine until I'd get low on coolant and overheat, but ran right on 80 - 82. So, realized the dripping was coming from a worn out water pump. Bought a Laso from Autohaus, installed it and although the leaking was going, now my car was running above 95.
I replaced the thermostat two times with no different results. Replaced the radiator cap, same results. Last item in the circle was the radiator. Today, I yanked the working and clear radiator from my "parts car" and put it in, alas, with the same results. It seems a bit cooler, maybe below 90 now.
So since all this extra heat started when I replaced the water pump, I can only guess that it is the water pump. It's such a simple part, I can't imagine what would make it not work properly...
Has anyone every gotten a "bad" water pump?
Thanks!
Thanks!
