Hi all,
I recently purchased a beautiful W210 and to my technical knowledge, it's pretty decent and everything is 100% in original condition.
However, after driving for a while now, I came to realize that while the A/C is running the cooling fan runs well at full speed and temperature stays right around 78-83dec C.
If I were to turn off the A/C and run depending on the engine temperature sensor, cooling fan only kicks in about 87degC, but the fan is not ramping up (slow speed)
as fast as it would when the A/C is turned on.
Do note my car don't have an AUX fan for A/C. Only 1 cooling fan for radiator & A/C condenser
Despite it not sitting well with me with the temperature while driving is above 80deg C, I didn't think too much about it until yesterday when I got a warning that came up.
"ENGINE FAN, VISIT WORKSHOP!"
When I rocked up at the workshop and got a diagnostic tool to run, it came up as following:
Error code# P2020-002: M4/3 (engine/AC electric suction fan), Short circuit to ground / Open circuit in wiring
*Note during this whole process my ran was running at full speed.
So, it confuses me how can it have an open circuit, or a short circuit as displayed on the error code whilst the fan is running on full speed?
The car engine was then shut off and diagnostic tool used to wipe out error code and when I started back the engine, the fault code went off and fan was running as per normal.
My mechanic is suggesting it's the fan motor; however, I am skeptical I think it may be the fan module, but I'm not sure if this model has one.
With the information above following are my question to the gurus of this forum please help me with:
1) Have anyone else encountered this?
2) Does my model have a fan module? If so what's the part number?
3) Confirm PN#A210 505 23 55 is the right part number for my car model fan deck.
4) Can i get a temperature sensor to start my low-speed fan at a lower set point, instead of 83degC maybe 70degC?
VIN#WDB2100482
