I am still working on getting the coolant fan to come on when car (’85 190E) is hot enough. I discovered that the old two pin sensor won’t activate regardless of engine temp on the dash. I can unplug the connector off the pin, jump both wires at the connector with say a paper clip, and the fan magnet will activate right away and fan will run (on water pump speed). Plug the connector on the sensor and no connection.
So I bought a new BEHR sensor for $40 and the first time I installed it, fan activated around the 80 mark on the dash. But after it cut off (3 or 4 minutes later), it never came back on when temp went even next to the 120 mark. Unplug and jump sensor wire at the connector and magnet will activate promptly. So there is always 12V available at the sensor connector. The sensor is just not being consistent in letting power get to the fan magnet.
I went to the salvage yard and got a couple used 2 pin sensors off the 300E & 190E (same for both). I installed one of the old ones yesterday and fan came on slightly after the 80 mark on the dash. However, after it cut off minutes later, it also won’t activate any more, even as temp got up close to 120 on the dash. While it is close to 120 and engine idling, I unplugged connector at the sensor, jump the wires and get fan to activate and bring temp down to around the 80 mark. I can only test one sensor per day as I have to let car cool before swapping out the sensor for another used unit the next day. So, when I get home from work this evening, I will swap the sensor out and try another. I also installed a new made in Germany thermostat.
What am I doing wrong? Does anyone know where the dash temp should be for fan to activate? Am I overlooking any component? Jump the two wires at the 2 pin coolant sensor and you will activate the fan every time. How can these sensors be tested off the car? I picked up 2 extra used units to try.
Greg
Greg
