2004 ML500,Sport; 2014 ML550; 2009 ACURA TSX
I have to replace the lower radiator hose. Small leak is noticeable and time to act. While removing the hose, I am going to replace coolant fluid as well. I have few questions.
1) How much MB coolant do I needed. 1:1 mix of MB and distilled water.
2) Where are the 2 engine drain plugs?
3) Drain and Fill? or Is there a need to flush? and instruction?
Thanks.
JM
02 ML320 06 ML500
1. 12.7 qts of cut coolant is needed. This info. can be found in the rear of your owner's manual.
2. Above each motor mount.
3. Why not?
