coolant type/ differential type
5232 3
does coolant type realy matter? as long as its aluminum compatible and low sulfar isnt coolant just collant. i read alot in this forum to buy mercedes only oils. but thats just so thay can charge you for the same product.
and how can you tell if you have a lsd differential or not? and what oil do you recomend for my 300sd synthetic?
Moderator
1987 & 1991 C126
Hi ladybee,
I don't know if your car has limited slip or not, but I just posted the codes a day or so ago. Look at the body tag on your car, area 6 for Optional Equipment. Limited slip is code 211 as you will see in the post below.
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1201466
Cheers, MBL
Depends on the day!
Mb coolant or the Zerex G5 (same stuff..). Don't use ethylene glycol (ie green stuff) and change your coolant every 2 years..it's worth it.
I use Redline Haploid gear oil 75-90W synthetic in all my MB's. Works great thus far and they All get a regular work out[:D]
Jonathan
