The car seems to run fine. but due to it overheating i cant drive pretty farDoes the overall performance of the car is affected
I haven't checked yet still a newbie not enough tools on the shelf 😂So, what was the resistance across the coolant level sensor? See post #3.
i am starting to think my previous sensor had no issues but the workshop had no idea what they were doing and just asked me to swap it out. but to answer your question. i can see the temperature in the cluster rise.I am wondering how you determined the used sender was good?
What scanner would you suggest i get? something inexpensive but goodEngine coolant thermostat starts opening at ~87C, fully open at ~102C. Without ac suction fan comes on at ~100C.
Scanner that you ordered will not even scratch the surface of R230. You have network of 25+ control modules and you need to access them all. That includes reading faults and actual values.
Computers/Controllers
Sorry if this is redundant. I would like to know how many computers or controllers a 2005 SL 600 has, what they control, and their locations. I'm trying to sort out some operating deficiencies and don't know where to check first for an assortment of issues. Any help is appreciated.www.benzworld.org
If you have decent modern smart phone start with Autel AP200. It will read faults and display live data from all R230 modules.What scanner would you suggest i get? something inexpensive but good
will work on these and hopefully, the issue will be fixed.I would still think your fan control module is the culprit, but fixing the BCM first is the go.
This is a hard pill to swallow as i am so invested in the car already 😂 😂. a big part of me wants to accept the challenge and be okay with taking a loss with the car as long as i can bring it back to 100% as an achievement... but at the same time, you are giving a valid point.I'm sorry about your story. With the BCM gone, those burn marks and it's wiring missing and cut out pneumatic lines (perhaps scorched or molten) your seller is a crook not telling you. Without extensive knowledge about the car it would be a gargantuan task to fix things properly. Selling and taking your loss really ought to be one of your options.![]()
Dear Witek_M - new to the forum after buying an amazing SL500 2003 R230 and would like to ask you a question re manuals and information. ThanksWhat scanner have you ordered? This sure looks like failure of radiator fan controller. Does ac work? AC should put fan at 30% speed.
