Hi, I have a 2003 sl350, the car has an overheating issue.. upon turning on the car the temperature light turns on and never goes off even while the temperature is around 40C*.
I took the car to a workshop and they told me that the coolant temperature sensor is bad (A0009050700).their reasoning for why the sensor is bad is, once they unplug the sensor the fan goes on super speed this show that the fan works but somehow it is not getting signals from the ECU to turn on maybe? I went to a local Mercedes yard, got a good working one, and placed it, but the issue remains the same, even with the new sensor once i unplug it, the fan goes on super speed.
I even did a radiator flush and added new coolant but the issue is still there... i want to go through the fuses, but I have no idea where the radiator fuse is.
i bought this car recently with this issue hoping it to be a quick fix but it's proving me wrong.. the car does have other issues but at the moment this is the priority.
any suggestions on what i should check or what could cause this to happen?
