Hi there all,
My '91 500SEC temp gauge reads 100C when fully warmed up.. This condition is seemingly independent of the ambient air temperatures which I've observed as varying between a low of 60F this morning to the mid 90's last week.
This condition is also independent of road speed and or sitting in traffic idling.. The temp may vary just a couple of degrees higher idling .. and reduces if the engine is revved to say 1000 - 1500 RPMs.. normal.
This means the auxiliary fan will run darn near all the time, something I do not care for, or feel needed when cruising on the open road at any speed.
I first got the car in the spring I found it had a disproportionate antifreeze to water ratio… Way too much antifreeze… That has been sorted to 50/50 mix now of the MB blue coolant. No change on the gauge,,,
It has a new Meyle 80C thermostat.
I changed out both coolant temp sensors at the thermostat housing.. (gauge & fan speed).
I found the radiator matrix weeping so it now sports a new BEHR radiator.. at the same time I blew out the A/C condenser from the backside with compressed air to get rid of any dead bugs & other schmutz that could block airflow..
Next week I'll be installing a new A/C compressor as the original is leaking… At that time both the temp & pressure switches on the drier will be renewed as well..
Today I disconnected the aux fan electrical feed. There was no change at traffic lights, and stop & go .. or on the highway for miles on end at 75 - 80 mph.. 100C. The viscous fan appears to be doing its job nicely.
Last week I drove my US spec 560SEC and it warms to 85 - 90ish only.. Like the euro 500, its indicated coolant temp never varies once warmed up.. The aux fan seldom engages… That has been my SEC 'norm' over the last 14 years of ownership..
I am curious as to why this happens .. and delving further, is it possible to have the 500 act same as the 560SEC?
The only clue I might offer is the US spec M117.968 engine has 9:1 compression ratio.
The German M117.965 5 Liter engine has 10:1 compression… and is pretty lively since the try-y install & cat removal..
Could the compression be all the difference?
Thanks,
MBL
Thanks,
MBL
