Hello, I've learned I have a small leak in engine coolant tank and I'm wondering how much is replacement part and how easy it is to replace? Thanks for your help!
10 Mercedes e350, 09 Mercedes GL450, 95 BMW 325IC, 89 Mercedes 260E, 84 Euro Mercedes 300D 4spd
replacement is very easy it held's by one 10mm bolt, from the top that you could see ,
and then there is one coolant level sensor under, dusconect rubber houses and then just lift it up as bottom sits in the rubber bushings
Thanks for help. I'm goin to order part or go find one at auto store and fix it myself and save some $$$ I think the part is $25-$50
Thanks again
i'm not sure about how much it cost, because from country to country cost will be different,
but once you have the new replacement part in hands you will understand even more how to change it.
what year is your s-class?
