Here is an update. after my last post I checked the pressure of the AC and I was expecting it to be low since it only blew hot air. To my surprise the pressure was very high, close to 200psi! when the normal should be between 30 and 45psi. I have no idea how it got to that level. Anyway, I pushed on the AC valve to release the pressure until I got to the normal range. I then took the car which was already warm for a 20mns test drive. The AC worked wonderfully, it blew nice cold air and today the outside temp over here in Raleigh is close to 90F. The engine temp remained in between the 80 and 90 mark. The engine fan message never showed during my test drive while as I explained before it would show everytime the AC was turned on. So it looks like there is some kind of correlation between the engine fan message and the AC pressure. I checked the AC pressure after my test drive and it was OK.
The engine did not stall on me during the test drive although I turned it off and on several times, one time after 5mns waiting. Should the CPS not trigger and error code? Anyway I will drive the car all the week-end and see if the problems reoccur.
