SLK32 AMG
Light came on last night.This morning,opened up the coolant cap and it needed a gallon of water to fill.No visible water on the floor.Any ideas? MB hasnt yert returned my call at 9am...
Adrian
2002 SLK 32 AMG, 2000 S 430, 2003 ML270 CDI
Try search on this forum, here is one thread
coolant leak
Check for coolant smell in the cabin floor, check for possible white streaks below hoses, water pump, etc. These should be obvious places. Intake manifold leak is a bit harder to find and nastier, too. Any white smoke from the exhaust? How quickly does the coolant disappear?
SLK32 AMG
Drove about 20 miles today a couple of runs locally,no fast roads.Tonight I added half a litre-16fl oz ,a quart??
My SA called-said not to worry-as the car is almost 4 years old it will use more oil and water .....I have NEVER seen the water light on in 10 years of owning SLKs.
Time for a new dealer??
Adrian
Apparently it should be half full,which it was,but I brimmed it! Will recheck daily.
L
Guest
If the coolant leak inside th engine from the intercooler, your plugs should show sign of corrosion. Pull it and check it out. C32 and E55 has these same problems.
