hi i have a 2006 c180 kompressor which is loosing a little coolant over a period of a few weeks there is no obvious external leaks or in the cabin from heater i did a compression test and all seems fine and also did a sniffer test at the coolant header tank for exhaust gases but all seems fine there i also have a fault code that the engine is running to lean.I have been told that it may be a cooling duct seal between the timing case cover and the crankcase allowing water into the oil pan can anyone tell me if anyone has heard of this problem before.Thanks
