1 - 9 of 9 Posts
1993 300E 2.8
Any idea how I could fix this? The tip of my drain plug got stuck inside head. Part number to new plug ?
1995 E320 Wagon
Drilling it out wouldnt be to bad. Punch the center of it first so the drill bit doesn't wonder
1993 300E 2.8
Probably going to have to remove engine as it’s very tight space
1995 E320 Wagon
You might be able to undo the engine mounts and put a jack under the engine oil pan (recommend a wood block between pan and jack) and jack it up for more clearance, a 90 degree drill is an option if space is limited.
1993 300E 2.8
Sure I’ll try to post back on a day off work will be getting in the way of a few repairs also cracked my water pump so there’s that
W124
You mentioned the block and you mentioned the head. What location are you talking about? Is this the block drain on the exhaust side of the block or something else?
1 - 9 of 9 Posts
