07 E350, 98 E320, 95 525IT BMW, 87 325IS BMW
how do i drain and refill the cooling system on my 98 E320? WILL I HAVE TO BLEED THE SYSTEM AFTER REFILLING? BLEEDING IS A MUST ON MY 525I BMW. THANKS FOR THE FEED BACK.
Yes, you have to bleed the system of air. MBs are pretty easy to bleed vs. BMWs.... Make sure to top off the reservoir with 50/50 Coolant(Aluminum Safe Coolant ONLY), Replace cap.... Turn Engine On, Set Heater to HIGH HEAT and turn On the Windshield defroster.... Rev the Engine for about 10 minutes(1,000-1,500rpms) enough to warm up the engine a bit.... Turn Off Engine, Open Coolant Reservoir Cap SLOWLY/CAREFULLY using a cloth rag(the system is now pressurized!). Refill/Top off the reservoir to max level....Repeat procedure until all air is bled OR the coolant level doesnt decrease
Gosh BMW's are easier all you have to do is turn a little screw and let it run until it starts pushing out coolant then close.
I just bought some coolant and purple ice so I will see how it does tomorrow. So I have to keep running the car and turning it off like that? Ron I am glad you brought this up.
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
I just changed the coolant in mine and bleeding the system wasn't necessary. I did remove the upper radiator hose though and filled through there as well as the reservoir. Make sure you use an approved coolant.
Len
'99 E300TD 75,000 miles
