2014 CLS63S SB
It's that time again, oil, plugs, filters etc-no problems there. The coolant though that's a different story mehtinks.
Here's what I am wondering. If anybody has a simple way to change the coolant can they please post it.
Now I've seen posts in the past mentioning the nut at the bottom of the radiator. In the same post they go on to mention that a vessel capable of holding about 2.5Gal should be used, but according to my owners manual the cooling system holds 16.5L, (3.6Gal). So how do you get the rest out?
Is there a valve/inlet somewhere on the block that I could connect a hose to and just run water through until it runs clear?
1994 s320
gumsie, you have to drain engine block right/left as well,on my s320 its on the pass. side,
as for the radiator , I just loosen lower hose.
