2004 ML500,Sport; 2014 ML550; 2009 ACURA TSX
Drain and fill, How much MB coolant Do I need ?. I currently have 2 of the 1 gallon jug that can be mix 50:50 to total of 4 gallons ready to use.
Thanks.
Discussion Starter · #5 ·
Correction - I already have 2 of the 1 gallon jug which can be mix 50:50 to total of 4 gallons ready to use.
Thanks.
· Outstanding Contributor
2002 ML320, 2003 A160, 2002 ML500, 2018 GLS350d
That's all you need. The ML500's system capacity is 12.0 litres or 3.17 gallons, so you have almost a spare gallon to flush it with.
You can drain it by rotating the drain plug 180 degrees anticlockwise. You don't need to detach the lower radiator hose.
