rca optical fiber interface
Bonjour,
Pour brancher un autoradio classic sur l'optique. w209 clk.
Mon idée est de sortir en 4 RCA out de l'autoradio vers un boitier convertisseur entrée (IN) et faire la boucle optique et ainsi je conserve la qualité de l'ampli et des hp sans modification de l'installation d'origine.
Ma question arrive, quelqu'un peut il me confirmé que cela peut fonctionné.
Merci
W221 & Audio Moderator
2013 S550
Bienvenue!
While this is an international forum, its principal language is English. My high school French is not up to being able to respond.
While there may be some folks conversant in French who can respond, you might get a wider response if you can also pose the question in English.
Hello,
To connect a classic car radio on the optics. W209 clk.
My idea is to take out in 4 RCA out of the car radio towards a converter entry (IN) and to make the optical fiber and so I keep the quality of the ampli and the hp without modification of the installation of origin.
My question is : can someone confirm if it works ?
The interface is :
Interface Audio Audi MMI Most 2G
Thank you
