Backstory: I bought my 2004 S600 with 78k miles and failed ABC. Had it towed to my house, (had to use a special race car trailer because it sat too low for the flatbed wrecker. I paid $2700 for the car, which was a "can't lose" price; the seller was just done spending money on it, and the $3k estimate for fixing the ABC again just pushed him over the edge. Anyway, I got a nice low mileage car (not a creampuff) for silly money. My intention was to delete ABC and go to coilovers from the get go. After a less than pleasant experience with Strutmasters, I ended up with a set of Yellowspeeds in the car, which I'm very happy with. Since my ABC system was ruptured, I have simply been running the ABC side of the pump dry, which I've heard may or may not work.
I've been enjoying the car for the last 6k miles, until recently, when the power steering began complaining. It became hard to turn at low speeds, and making uncomfortable groaning noises. Info on this forum indicated that the ABC pumps do not last long running dry, but a popular conversion for V8 cars was to swap power steering pumps from an air ride car. Unfortunately for me, it seems no one has done this on a V12 yet. User Cowboyt is running coilovers on his V12 with a fluid recirc to a regular ABC pump.
I like the idea of running the V8 PS only pump on my V12 car, but there are some obstacles, which as far as I know, nobody has solved yet. So I got busy trying. First, I bought a used PS only pump off of an S500, with the idea getting both pumps in my hands to compare them and see if it is worth doing. Comparing pictures was very promising! Then, I removed the tandem pump from my V12, (and you know what a pain that is) and got them on the bench together. Well, there are some obstacles!
1) The pulleys don't match. V12s have a 7 rib belt, V8s have a 6 rib belt.
1.5) Pulleys are not interchangeable
2) The mounting holes are the same pattern, but there is a lot of space to make up just to get the V8 pump to match the V12 belt line.
3) The rear mount is different.
4) The power steering line output is in a different position. Big problem!
5) The V8 pump mounted fluid reservoir interferes with the V12 coilpack.
Photo shows my V12 tandem pump (top) and a V8 PS pump (bottom) with the mounting tabs roughly aligned. Offset is significant.
http://www.benzworld.org/forums/attachment.php?attachmentid=2186489&thumb=1
So, my ideas were that I would need to custom fab something(s) to make this work. But What?
1) Spacers/mounts/bracket to match M275 beltline (not too bad, if you get the measurements right the first time)
2) Custom 7 rib pulley to match beltline (LOTS of machine time =$$)
3) Custom PS output line (Again, not too bad)
4) Rerout reservoir supply to OEM remote tank. (Easy)
5) Custom PS fluid reservoir
6) Convert V12 to 6 rib belt to match PS pump with off the shelf Ford part (Easy!)
If none of this works, I will buy a reman ABC pump, and fab a fluid recirc system like Cowboys
Project in progress, updates as they occur!
