2006 CLK350 convertible
I just got this clean 2006 clk350. Yes, I know about the balance shaft... When I operate the top the display says something like "Top: Visit Workshop!". However I scanned for faults and only got one pending p0128 which is about the thermostat. Any likely possibilities as to what's wrong with the top?
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Welcome to the forum! Please take a moment to update your forum user's profile to list your location and car year/model. This will help tremendously as people try to help you. Also, you posted this thread twice. Go into the to the one, choose the "EDIT" button, and then you will have a "DELETE" button to get rid of it.
It sounds like you have an error in the soft top control module, but you are using a generic OBDII scanner. That only reads ECU codes. To get codes from the top controller, you need to use a tool that reads MBZ's proprietary systems, such as SDS (dealer's Star Diagnosis) or iCarsoft. Once you have the codes, we can help.
