1997 e320 runs some times and then will not run at all just cranks the crank position sensor R&R ran good for a few weeks then quit MB shop said the wire harness needs to be R&R due to dry rot this does not sound right to me anybody have any idea's
ok where is this relay under the seat in the backHello
Could be wiring issue, dry rot, or not.
Could be K40 relay module issue. They tend to go bad as they age a lot.
I assume your mechanic checked the fuel pressure.
I checked fuel pressure its good I found the wiring harness they say is bad. I think the ecu maybe bad i can not read any codes give me a link failure.NO check engine lightHello
