2005 S430
My 2005 S430 air struts are not liking the real cold winter weather in Montana. They often take considerable time to air up. I've heard that the conversion to standard struts/shocks does not adversely impact the ride. Anyone done this ? Best vendor for the appropriate parts ? Good idea or bad ? Cost versus taking the car to a Mercedes dealer that likes stick ups as much as Jesse and Frank James and having the original equipment repaired / replaced ? Any advice appreciated.
If your struts are taking a while to air up, I would imagine the compressor is on it's way out? Also, if the compressor needs to pump the system up with some regularity there may be a small leak in the system somewhere.
I had a coil conversion on my old w211 & the ride sucked. Way too stiff. That was an old strutmaster kit, so there may be better options out there nowadays.
2005 S430
Thank you.
Jim
2003 S500 2007 GL450
Jim,
There are several possible causes for your problem. If you are willing and able to do some DIY repair work on your car, most can be taken care of at a reasonable cost.
A Mercedes dealership is not usually a good idea. The last training classes on your car were held at a bout the time your car was sold. There are very few of those trained techs at the dealerships now. All too often, you will get the "Yeah, it's expensive - now go away" quote for your car - and even if you do get a straight-up quote, it will still be very expensive at $125 - $175 per hour, plus full Mercedes list price for the parts.
If you are lucky, you might find an independent garage that has SDS (STAR Diagnostic System), the computerized diagnostic/shop manual/test system that is virtually a necessity to maintain and repair your W220. The "indy" can also procure parts more reasonably. While rates vary greatly in different areas, you can usually expect to pay $75 - $150 per hour. - hopefully for the actual hours the shop spends on your car.
I suggest that you start by learning some basics on your Airmatic system. Go here Airmatic - W220 S-Class Encyclopedia and read thru the article.
If you are willing and able to do some DIY repair work on your car, most common problems can be taken care of at a reasonable cost. You can buy or build SDS for $450 - $650.
One possible cause for your problem is moisture in the Airmatic system. In very cold weather, the moisture can freeze the solenoid valves in the Valve Block that the control system uses to distribute the compressed air that operates the suspension. You can make (or possibly buy) an in-line filter that contains dessicant to dry the air.
Another possibility, as already mentioned, is that the piston in the Airmatic Compressor is worn. You can buy a kit to rebuild the compressor very reasonably ($25 - $50), and installation isn't difficult.
While leaking struts are a common problem, it is very unlikely that all four struts have simultaneously failed. Used struts can cost $150 - $250 on eBay, Cheap Chinese struts (NOT recommended!) about the same, Arnott rebuilt (life-time warranty, recommended) $360 - $375, Bilstein new (recommended) $825 - $850, Mercedes rebuilt $1000 - $1200. All of these are estimates for single struts.
I do my own maintenance and repairs, and would never consider going to conventional suspension. YMMV.
Here is an article on on the subject - I don't know how old it is. S-Class W220 Aftermarket Air Suspension Struts and Conversion Kits – MB Medic
You can find numerous threads and videos on the subject.
A final opinion...
Driving a W220 is a joy, and can be affordable if you are able and willing to do most, if not all, of the necessary maintenance and repairs. If you are willing to pay an independent shop to do all necessary maintenance and repairs, it will be expensive. If you can find a dealer who will work on your W220, it will be VERY expensive.
Good luck.
