1998 SLK 230
Considering buying a 2003 C240 2.6L, AWD with 155,000km, any comments on what is good and bad with this car would be appreciated, and what faults should I be looking looking for and what is a good price with this milage :confused:
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Besides the obvious stuff (oil leaks, service records, body damage, etc.) check to make sure the notorious Valeo radiator has been replaced. It was known to let coolant and transmission fluid mix and thus kill the transmission.
Since I am currently driving the exact model the OP is looking at, I just went out with a flashlight to verify the style radiator I have. You see, this C240 recently had it's transmission replaced, so I was getting nervous I had the "bad" one. As luck would have it I have the "good" one going by the photos in the link... whew!
To the OP, it really depends on the price vs. condition as to whether it is a good deal or not.
Don, MBZ's "$Matic" system is pretty much bulletproof. It uses tried-and-trusted open differentials and the ABS/ESP system to regulate wheelspin. It works very well with minimal extra components. About the most serious problem I ever hear reported is some irregular brake pad wear, but that's it.
