380 SL 1983
83' SL380. Connection to the idle selonoid, temperature sensor, oil temp sensor, etc are shot. the problem is ing the interface between the female (barrel) connector to the male pins. I resoldered all for good wire to barrel contact but the normal ( contact) forces are gone and the contacts are intermitant. I squeeze the barrels down but they just expand upon contact and have no retentive forces left.
Can anyone provide directions as to where I can get replacement connectors?
thanks for your help,
380 SL 1983
Thanks for your response. Attached are the connectors I am looking for. Any help is greatly appreciated.
The larger connector is that which attaches to the idle control unit located behind the glove compartment.
