'84 300D/ dakota benz trk. Sold... miss it. "88 260E '91 190E 2.6 '89 Volvo 240DL "85 300D
i recently saw a post on here on how to test the glow plugs while installed in the engine. i would like to confirm this procedure and my results.
i set my meter to continuity, ground the black lead, test each of the 5 female connectors coming from the glow plug relay. from my understanding, if i have continuity, the plug is bad. if thats the case, i have 4 out of 5 that are bad! am i testing this properly? the only lead that did not have continuity is the pin that is by itself at the bottom of the connector. please advise. i could take the GP's out and test individually, but if this testing procedure is accurate, it would save time doing it this way.
'73 450SL, '83 300CD, '01 E320 4matic
wow.
Forget about all that.
Unplug the plug at the relay.
Ground the black lead on your meter.
Set the meter to ohms. Use a digital meter.
Touch the red lead to the 8mm nut on each glow plug.
Each GP should test around .5 ohms.
If more than two are bad, replace them all.
money pits of various forms
.5-.9 or there abouts. I personally just test at the GP tip but to each their own.
