1 - 11 of 11 Posts
91 500SL 80K / 2003 E500 120K (Runs Perfect!)
Little help would be appreciated...
I was reseting my ADS light with Pins 1/9/16 while I was in the process of doing that I heard a beeping tone in the car and noticed that the seatbelt light would not go out after attempting the reset, I also noticed that there is no power now to the soft top controller,
rollbar controller, turn signals and windows !!
When I start the car I now get a steady beeping which sounds like a busy signal all while the Seatbelt light flashes and stays steady?
Thank you in advance!!
fuses ...
All checked they all seem good ...I also re-seated them ...which fuse controls all these items?
Thanks again !
Discussion Starter · #5 ·
Damn ! you were right, I had to check it very close... I there was one that was blown...
Presto everything works again....
So I still need to reset my ADS light (my fluid was low) how do I do that ....
Thanks RKH !!
2000 Obsidian Black Metallic Mercedes SL 320 V6 (SOLD) 2012 E 350CDI Cabrio 265 PS
Thanks RKH !!
henryt111 I would suggest to us the ESP/ASR resetting method that is with the engine running turn the steering wheel lock to lock. I have no idea if it will work but if you are luck enough the ADS reset is the same that the ASR/ESP one.
Fingers crossed here.
Cheers.
Discussion Starter · #8 ·
Msbarsi... Thank you! I did try that several times ...but my ADS light came on due to low fluid state in the Resivore tank.... I think once you get a fault it has to be reset via the diagnostic connector in the Engine compartment.
Since my sl is pre-1995 there is no OBDII connector and I believe I need to reset it using Pins 1 - 9 - 16 but I need to know what I need to do in order start the computer to pulse out the error code?
Thanks!
Damn henryt111 I'm sorry it didn't work but a this point I think your quicker solution is, if you have a dealer close to you, to sweet talk the guys there into resetting your error code for you for free with the Star computer since it's a 5 minutes job.
Fingers crossed still.
Cheers.
· Outstanding Contributor
2005 SL600, (2) 2003 SL500
Take a paper clip or wire and short socket #9 to socket #1 (or chassis ground) for 2-4 seconds. After a moment socket #9 will indicate a code with a pulsing voltage that you can see with an LED, test light, voltmeter, etc.
Discussion Starter · #11 ·
Bob Terry to the rescue!
That did the trick!! once I got it to pulse ...I held it for 10 sec i heard a click and presto the ADS light went out ...and the ride is nice and smooth again...relatively speaking ...
Can't thank everyone enough.... this saved me 160$ in diad costs at the stealership!!
Thanks again !
1 - 11 of 11 Posts
