1976 416.163 125HP Doka
Hey now.....how hard is it to do a compression test on a 416? I have done em before on cars but not on a diesel.....tips, suggestions, etc.?
Thx, HW
Basically the same principle but a little more work, the injectors are harder to remove and reinstall that spark plugs, those little hand pressed dial gauges are harder to press against the injector hole because of the higher pressures you will have compression leaks, a more elaborate gauge and adaptor may be needed.
