I am in the market to purchase a 2007 or later s600.
I am curious, having owned 4 Benzes previous which all gave good service with a minimum of trouble, if these cars have major problems that run through the line.
The one that I hear about most often is the oil cooler leak on the V12 which requires that the entire upper half of the engine be disassembled to replace a couple of $50 gaskets. Labor quotes for this procedure seem to run between 50-60 hours. So this isn't minor and letting it go is not an option since it dumps oil all over the exhaust system and catalytic converters.
The one I saw being redone on You tube was an earlier car, perhaps a 1999 so maybe there has been a permanent factory fix. I am currently driving a 73 300SEL 4.5 with 285,000 miles on it and other than routine stuff, brakes, plugs, front suspension pieces and a bladder or two it has been a real trouper. Original non smoking engine and original tranny.
Info on anything to be on the lookout for on 2007 or later S600s would be greatly appreciated.
Thanks in advance,
Jim
Thanks in advance,
Jim
